okay, so here they are from the SAME receiver. 722...one shows tuner one the other tuner 2. note the Locked - Acquiring Satellite Name on tuner 1.
The TV that is connected to tuner 2 works great...all channels no issues. The one on tuner one is missing the channels on Trans 32.
I removed the Dish Separator, wired directly to Sat 1 input and had same issue...did a check switch also.
Thoughts? Bad receiver? new software needed? im running L617....
menu 6-1-3 let the receiver run through the diagnostics. At the bottom of the screen you'll see "details". Hilite that and hit select. Scroll down until you see "set top box health"
The values that matter are 0,1,2,4,7
value zero should read 2 or less above that there is a hard drive issue
value 1 should read 10 or less. above 10 indicates a hardware failure-driver
value 2 should read zero. above zero and there potential hardware issues
value 4 should read 200 or less. above 200 indicates the receiver is locking up
value 7 should read 4 ONLY!! Any other value indicates a hard drive malfunction.
If in any of the above cases the values are outside tolerances, the receiver needs to be replaced
now back to the diagnostic screen. if at the top of the screen if you see "problem detected see details", the first page of the details will tell the user if there are problems with the LNB. One of the most common problems is "drift". If the test indicates "LNB drift", the lnb(s) must be replaced.
One other thing you can try. Disconnect the seperator entirely. No connection to the satellite receiver. Run chk switch. This is "clearing the matrix". Reconnect, run chk swich again. See if that works. Also you can try reversing the ports from the seperator to the receiver.
