We have a new RV home in a remote location that will only accept satelite TV. I currently have gone under the trailer to start wiring for phone and tv. THe builder wired all the phone and TV connections using CAT5e wiring, Inside the trailer are three COAX Wall jacks, for TV's. When I pulled the Wall jacks off to expose the box, I see coax going behind the wall of the trailer. SInce the sections are already joined, I cannot trace any of the wiring behind the walls, so I have no clue what connections are made to convert the COAX to CAT-5e. Under the trailer there are three cat-5e wires that I have traced to the wall jacks using a tone generator. I called the builder and asked where the coax terminates and he told me all the new houses are wired cat-5 for HI def and latest technology, and the professionals who install the tv will know what to do.
Since I am closing up the underside of the trailer, I want to extend the wiring to the outside. I never heard of wiring any satellite dish using CAT-5E. I know a phone connection is needed for the cable box download and there is another phone jack next to the coax jack so thats not an issue. I always thought cat-5e was used for just networking. I have no problems hooking up the phones as i only need tip and ring, the rest of the wiring is overkill, but ill keep it for spare pairs if needed.
I don't want to set up a network hub, just to be able to watch TV in one or two rooms. don't care about having separate channels either, maybe kids will watch a dvd in one room while others watch a tv movie in other but for most part we will most likely all watch the same thing at same time and only have one tv at all.
can anyone tell me first of all if this builder wired the trailer correctly for TV or should they have used coax for the tv connections and not cat-5e.
can anyone tell me if its possible to hook up a dish to cat-5e. IF so what kind of equipment is needed.
If this is possible, and I only use one satellite dish, can I wire the three cat-5E terminations to one termination block and use a converter to the satellite dish
to split the signal to all three wall plates.
I ahve wired cat-5 netowrks before. I can use krone blocks o punch down the terminations and I can jumper everything to one connector if needed. I just dont know how to convert 5e to coax and if it will work with a satellite dish.
thanks for any advice
