I'm trying to record NASA TV using a Pansat TC-1000 receiver. I have the receiver hooked up via eSATA to an external HDD formatted to NTFS. I can record to the external HDD and play back videos using the TC-1000, but when I plug the external HDD into my PC (again, via eSATA), I can't view the files. I can't see any files at all. In fact, my computer doesn't even recognize the external HDD as an NTFS drive, and to use it at all I have to completely reformat it (back to NTFS). The odd thing is, even if I reformat it, I can still play back previously recorded files using the TC-1000 -- even though I can't see those files on my computer.
Can anybody explain what's going on here? I've called Pansat, but they weren't very helpful. They claimed that when the TC-1000 records to an external HDD, it doesn't change the filesystem, so it should still be NTFS, but the fact of the matter is that the hard drive becomes unreadable. My computer doesn't even recognize it as an NTFS volume. So of course I can't even see the files contained within. Even if I could, though, Pansat also says that the files are encoded using "FTA MPEG-2," which didn't make a lot of sense to me, since I thought MPEG-2 only came in one type.
In any case, Pansat says I would need to find a hard drive that can read files recorded as FTA MPEG-2. My question is: what do I have to do to be able to use my PC to view the files that my TC-1000 records onto my external HDD?
Many thanks!!
Many thanks!!
