I am having a problem that I can't seem to fix. My DSR 920 had been having problems going back and forth between satellites - would lose counts and not end up on the satellite. So I was constantly having to retune.
Then it basically just quit moving. Always got the reached limit error no matter which direction I tried to go. So I changed actuators, am using a Saginaw with a 10k pot. What I find is that the receiver will move the actuator, if I go a click or so at a time, but if I hold the right or left direction down I get the limit error.
Set Limits screen will not let me set limits. The actuator will move but the numbers don't change. Both actuators do this.
Do you think a master reset will help? I have the dish blocked on G3 now, the actuator is just on the roof so it is free to move.
What do you guys think?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
