Can't record HD LIL and OTA
teamerickson
1,716
El Dorado Hills, CA
It looks like you can't record using the OTA and the same HD LIL program. Has anyone else been able to do it? It tried to tape Earl on OTA and HD LIL and the 622 kept skipping the event.
It's skipping it because is sees it is a duplicate. Go into the daily schedule (menu-7), make sure "show skip" is selected, select the skipped event, select restore. It'll give you the option to do this once, or to permit duplicates everytime for this timer.
oops...you seem to have figured it out while I was typing...
I tried changing the locals from HD enable to disable and that didn't work. It still reconigized the HD LIL from 6395 as the channel 3 local. I'm going to try the local setting of SD enable and see if that helps. It would be nice to be able to record both shows in HD in case the OTA goes in and out.
Suggestions Needed for Dish Network Installation
Uplink Activity For WeD. May 10th 2006
