southofi-10,
If you could get a hold of a LNB that is in the 12.2~12.7 Ghz range such as a "Directv PARA TODOS" you could make this work with no problem.
The procedure is to open/remolve the the cap/cover, take a piece of plastic about the thickness of a credit card, or an old old debit card.
As you look into the throath of the LNB cut the piece of plastic to fit into the throath oproximately 1/2" from the the bottom of the cavity and flush with the top of the LNB.
Here is the most important part... place and clock the the piece of plastic at an angle to be between 7 and 8 o'clock on the bottom, and the top will fall between 1 and 2 o'clock.
Glue the two top ends of the plastic card to the throath as clocked with whatever you desire, let it set and dry, replace the cap/cover, point the dish and modified LNB toward the 118.7 satellite, enjoy.
avenger.
