hey guys, I would appreciate some help getting setup.
Everything used to work just fine until a few months ago, when suddenly the Bell guide stopped recording the shows we have setup on a periodic schedule.
I went into my bell menu and found out i was only picking up signal on nimiq82.
Took my ladder out, started playing around with the dish. Only the rotation screw was loose, so im assuming that's what is wrong.
When I rotate the dish left, im able to get 100% signal on nimiq91. When I pivot right again, Im able to pickup nimiq82 at very high strength. What im unable to do is pick up both. I went veeeerrrryyyyy slowly in between both sweetspots, and at no point in time am I able to pick up both.
I chatted with a bell tech guy, and they gave me the exact coords to use. My skew was way off, so I adjusted that.
The elevation meter doesnt have a clear indicator. Its basically a screw, and doesnt have an arrow to tell exactly where the setting is, I assume its the edge of the screw...I marked the current elevation with a sharpie pen and I adjusted to what they suggested (35.7)
With those 2 settings changed, i cant even pick up one satellite.
So i reverted back to the old elevation and rotation, but kept the new skew.
Again i can pick up a strong signal on both, but not at the same time.
Please help me!!!!!!
