Hi! I hooked my jumper from top(ku port) to LNB, hooked RCV to Receiver and can't get c-band to come through. I get Ku perfect using 10600 freq. and 22k switch on. No c-band using 5150 and 22k switch on or off, nothing. What am I now doing right?
chadg2 said:i'll go with (2) lines and bypass. Thanks much!
chadg2 said:I already have ku freq set at 10600 with 22k set to on, but my problem was c & ku switching using (1) cable with a 4-port diseqc installed inside the house to control other dishes hooked into the system.
iceberg... the ecoda is able to pass diseqc commands while 22khz is always resident on the coax when applied.
