I searched thru a lot of posts here last nite. I now understand my questions better but still dont know the answers for sure.
Coolsat 4000 pro
SG2100
Fortec 80cm dish
Coolsat KU LNBF model CS-LNBL, RF 11.70-12.20Ghz, IF 950-1450,Lo 10.75 Ghz
No diseqc switch installed
location 49.7N, 111.6W
Nothing loaded into receiver (ie. channel lists)
Motor elevation is set, true south is very close (my field is seeded with GPS to exactly 180 degree) so I aligned dish to my rows in the field.
Used Satellite Antenna Alignment program and it gives an "expected measured antenna angle". Put a straight edge on dish from top to bottom (when at true south) and measure with angle meter. Found the dish to be a little low, so I readjusted. Experience and reading, a lot of dish elevation scales are not very accurate.
Could someone walk me thru "dish setting" and "motor setting" menu's for the coolsat with this LNB. (figured out one half of the dual lnb was dead, so I switched to the other input, now I get signal level, but understand quality is the only one that means anything)
Dish setting
1)Satellite - saw a recomendation for my area to use Satmex5
2)LNB power - ON
3)LNB Type - Single
4)LNB freq - ??? could someone also explain how to figure this out
5)22Khz - Off
6)Diseqc - Off
Motor setting
what freq (TP) should I use
If I get all the menu's set up right, then I can go play with aiming more without banging my head into a brick wall!!!!
thanks
Coolsat 4000 pro
SG2100
Fortec 80cm dish
Dish setting
2)LNB power - ON
3)LNB Type - Single
5)22Khz - Off
6)Diseqc - Off
Motor setting
thanks
