Ok, looks like I found the problem. I had the pc set to 192.168.1.10 and the Azbox the same. I changed the azbox to 192.168.1.20 and it now connects. I'm almost certain I tried that last night and it wouldn't work. Maybe I didn't press the setup button afterward? I must say that even when I do press setup it says connecting then, connection failed, please try again.
Ok, now I'm cooking with gas. I had never been able to send files to the Azbox using the editor. I always got Run time error 9 subscript out of range. (See I remember it by heart
) It seems that I had never bothered to change the password in the editor to that of the Azbox. I assumed it matched because when I would click test IP connection, it said successfully connected. With all this happening now, the test username password button really caught my attention. I tried it and no dice. I then changed the password to "passwd" (which I originally got from a how to post by Lak and linuxman) and the editor now connects and will send files to the Azbox. It always received the channels from it before. So far it's looking like a blessing that I had this lockup and ensuing frustration (even though I thought I was gonna have to send it back to the Azbox factory to get it fixed) it's forced me to redo this stuff and now has me able to use the editor to send instead of filezilla
Anyhow, now maybe you can answer something else.
The sat list I created from the xml site and edited on my own has a couple of problems. I added all that I could see and got rid of those I can't like Eurobird etc. I added a custom satellite for ESPN feeds. It's all C band frequencies with a SR of 29270. I made the orbital position 90*W just for the heck of it. It still appears at the end of the list but, that's not a problem. I also made custom sats for TNT/TBS which is all C band frequencies with SR 24770 DVBS2 etc. I did the same for CBS, all C band freq, SR of 29860 S2 etc. After loading, it shows the ESPN in the antenna setup but, does not show the TNT or CBS. I wonder if the S2 transponders are causing that or what? The other problem is all of the frequencies and TR I put in for every satellite it only shows the first number of TR freq, and the first two numbers of the SR. Obviously this is useless. Anyone know why that's happening?
I've got C and KU sats for all of them that have both so, I wondered if maybe the Az will only allow so many satellites but, thinking about it, there are a ton in there from the factory with all the east and west birds so, I don't think that's it.
Thanks so much for all the help and if you can answer the smaller problems I still have, that would be great.
