Can someone else try this thread?
http://www.satelliteguys.us/dish-network-forum/133763-ciel-2-launch-delayed.html
I am seeing the same issue and am investigating.
I am looking into it again.
When someone trys viewing it, the server load goes up. (which is strage since the database in not on this server) and the Database server itself shows no issues or load.
Got to figure out why Apache and PHP dont like that thread.
Without knowing the 1st thing about vB, how do you determine that a message or messages are the problem ?Ok fixed. I had to remove two messages that were causing the error.
You go into the database and disable posts one by one until the thread loads up properly.Without knowing the 1st thing about vB, how do you determine that a message or messages are the problem ?
Hehe, so one-by-one... that still seems convoluted. You can't disable, check, re-enable then unless it's always just one post that's the problem. When it's two or more, you've got detective work to do.You go into the database and disable posts one by one until the thread loads up properly.
It might be my fault.
I was trying to post 2 quotes from yahoo news along with the url for those stories.
