OK, guys what am I doing wrong?
I am trying to set up RV reception with Directv. I am at home with a clear view of the satellites (using Dishpointer app), using a new 3-LNB (NOT SWM) with a new slimline reflector. The mount is plumbed with a carpenter’s level.
I cannot get a lock on any satellite using the AIM meter, Satlook lite meter, nor the receiver (HR22-100) and tv combination. The AIM shows a strong -20dbM signal strength and I can peak it in azimuth and elevation. I am told that the 3-LNB does not care about tilt, although my tilt is set to 73 degrees as per the dishpointer app and the AIM. The AIM shows all X’s in the EIV test. The AIM also shows 13vdc at 210ma to the LNB.
The AIM and Satlook Lite meters are good since I can hook them up to my home dish and get lock on all satellites.
For my zip code I should be at 200 azimuth, 53 elevation and 73 tilt. The dish peaks (-20dbm) very close to those values, but no lock.
What am I doing wrong? Any suggestions other than tracking down an installer and paying him/her to analyze my problem?
