Welcome to SatelliteGuys edited to remove er from recordpmetty said:I am looking to upgrade to HD. Can the 942 record from either tuner? Can it do it simultaneously?
Thanks - Phil
One better - you can do all that and watch TWO previously recorded programs at the same time.lakebum431 said:In fact, you can record from all 3 tuners (2 satellite and 1 OTA) and watch a previously recorded program at the same time. Feel free to ask any more questions, we're here to help!
SimpleSimon said:One better - you can do all that and watch TWO previously recorded programs at the same time.
Is that correct? I thought you could set a preference from which tuner to record particular program. I'll give it a try when I get home.jergenf said:In dual user mode you can record from only 1 sat & 1 OTA using your IR remote but meanwhile the UHF remote can record from the remaining sat tuner.
Yes - IF AND ONLY IF the tuner has ALREADY been "watching" that show for you.long_time_DNC said:The 942 is a blast! You can even go back in time and get the first half hour of a program (or movie) that you've missed. Just hit the rewind button within the first half hour and press it again get it faster, then fast-forward to live TV to watch it from where you started.
There are other ways to get the first half too, but I found that one to be the most amusing/amazing.
I'm glad you mentioned that, since I left inadvertantly that part out. Yes, you have to have been on that channel in order to go back and the previous 30 minutes of it.SimpleSimon said:Yes - IF AND ONLY IF the tuner has ALREADY been "watching" that show for you.
long_time_DNC said:I'm glad you mentioned that, since I left inadvertantly that part out. Yes, you have to have been on that channel in order to go back and the previous 30 minutes of it.
An hour? I thought it was only a half hour. Thanks for the new info!SaltiDawg said:And I'm sure that both of you meant to say you could go back up to an hour , rather than a ½ hr.
Actually, it depends on the receiver - some have a TWO hour buffer.long_time_DNC said:An hour? I thought it was only a half hour. Thanks for the new info!
