Can my existing VIP 622 setup be used to replace it with VIP 922 and keep the rest of the setup?
gixxer
36
Hi, couple of pictures below showing the outside dish (dish 1000), splitter and power inserter i have with the VIP 922,
Can the above DISH parts reused as they are with VIP 922? If not, then what part need replacing?
Thinking about replacing the VIP 622 with VIP 922 unit.
Thanks much!
should be just fine as the 1000 you have is looking at the same sats needed for the 922 as the 622
Hi, following is the screenshot from the VIP 622's System Info One screen, showing the Sats 119, 110 and 129.
Am i good to go in keeping the Dish parts and just replace VIP 622 with 922?
Thanks much!
The cable configuration between the 622 and the 922 are identical. The only difference is that the internet is optional on the 622 and the 922 requires it.
The 922 ships with a fancy 3 way separator/diplexor (2 dish connections and an OTA). I just used my existing 622 cables (my antenna was on a separate cable anyways).
Upgrade, locals, dish question
922 Remote (32.0) - Can it do a 722 on AUX?
