If you have 2 dual LNBs as you describe you don't have a Phase 3 dish and aimed correctly will work as a DISH Legacy system. Put the 2 dual LNBs in the 119 & 110 positions leaving the 101 empty. You will need to use DISH SW-21 or DISH SW-64 switches to combine the outputs. You can probably go to Ebay and buy a Dish 1000 or a Dish 500 for what you will spend on the Directv oval dish.jmata said:I have a Direct Tv dish with 2 dual LNB's with sat 101 119 and 110 can I use that same dish with DIsh Network programming?
