I've searched and found conflicting information. I currently have a 622 and a 722. The 722 is fed from 2 ports on the dpp44 and the 622 is fed by 1 port with a separator. I do not have a power inserter and never have. Some people say you must have one and others say you don't. The installer apparently didn't think it was necessary or was too lazy to install one. Currently the 722 is on ports 1&2 and the 622 is on port 3. Port 4 is spare. The ports going to the LNB's have 110 on port 1, 119 on port 2 and 129 on port 4. I disconnected 118 from port 3 to eliminate the ota timer issues. When I disconnected 118 I also moved the dpp44 to the basement where I have easier access. It was originally in the basement prior to the upgrade to the 1000 dish. It was at that point the installer moved the switch to the roof. I'm guessing he did that to avoid running a 4th coax from the roof to the basement.
Can I install a vip612 on the 4 port using a seperator?
Do I need a power inserter.
Are there any other issues with this setup?
