Hi,
Can somebody help me ? I am a rookie in this area !
I currently use a 30" (76cm) WineGard dish and a SamSung DSR 3700 receiver to watch FTA program in Telstar 5 (97W).
I also has a DirecTV receiver DSX 5350 from Phillips (I were a DirecTV subs, until 2 years ago, when I decided to switch to FTA).
Here is my case:
1) DirecTV offers SBTN (international language) program, which transmits from the Galaxy 3C in 95W.
2) I only want to subscibe to DirecTV Basic program (9.99$ basic fee + 14.99$ SBTN fee = 25$ total cost). And I don't need any other programs (like Total Choice, Preferred Choice, local, ...) at all (ie. I don't need 101, 119, ...).
My question is: Can I use the current 30" FTA disk + its LNB + the Phillips DSX5350 to get the SBTN channel (2072) ?
Here is what I tried so far:
0) I use the Winegard dish + its LNB (wideband ?) + the Phillips receiver (not the Samsung 3700, which I think only good for FTA).
1) My zip code is 85225 => Azimuth = 151 (ie. compass = 139) and Elevation = 47
2) On the Phillips receiver, installation screen, I pick transponder 15 (this is what LyngSat says reserved for SBTN).
3) I adjust the dish azimuth & elevation a lot, but signal strength is always zero !!
Does anybody know what I am wrong ?
Can mix and match (use FTA dish/LNB + DirecTV receiver) like what I did will work ?
What I suspect is that SBTN on transponder 15 is Hor. polarization, but the DirecTV receiver (which always works in LHCP or RHCP) doesn't know about this. So the voltage (13/18V) it sends out to the LNB is incorrect, the LNB confuses, and therefore no signal at all ??
BTW, I know DirecTV require the 36" disk to get the SBTN in 95, but I guess probably 30" is OK.
Hope your guys can help me out. Thanks a lot !
Here is my case:
