Someone informed me I could use my (just purchased) 10 year old Uniden Receiver with its 36 volt power supply to control my 12 foot Dish and Actuator Motor and then thru a LNB Splitter ?? still use my existing ViewSat 2000 Extreme Sat Receiver as well. Here is the quote:
Your (Uniden 9900) receiver is still good for a positioner for a dvb receiver and there are still some analog feeds on it.
You mentioned having a Viewsat Extreme 2000, all you need to connect it with the Uniden is a LNB splitter. You'd connect the "direct" path to the uniden and the other one to either your Viewsat or one of the ports on the 4x1 switch that came with the receiver and set it's lnb setting to 5150.
Is the above possible? What type of LNB Splitter would this be? I am totally lost as to how the above explanation would work, ie a diagram or drawing of the above setup would sure help!
