My family bought our house about 6 years ago, and has only had one tv with cable since. Recently, I purchased a new tv for my bedroom, hoping to hook up the cable. My room had an outlet without the connection (just the plate with a little hole). I opened it up and attached the coax connector myself (the wire was sitting inside the outlet). However, when I turned on my tv, it receives no signal. I am sure that the tv is not the problem. My question is, where should I look to try to fix it? I think that the previous owners of the house may have switched the cable off upstairs (where my room is), but I may be wrong. Our house has no basement, and when I took some plate off outside labeled "TV" (by the gas meter), there was only and empty wall with some wires, but no central hub of cables. My parents would not want me opening up the wall to inspect myself. How much would a professional cost to come and make it work? I am very inexperienced with cable, and any ideas would help. Is there a standard place for a cable panel with switches and such in a house? I have looked but I may be chasing something which doesnt exist. Reply if you have any questions or if I explained badly, which is likely. Thanks in advance.
