Well, I am done "checking" the unit for now. Blind scan works fine, and puts in new TP's into satellite list. Manual scan will work, but must have a TP entry. And the next contestant on the Price is Right; come on down; will be multi-satellite multi-TP scan; MOTOR ENGAGEMENTS.
However, if you do not want the results of my torture chamber test, do not enter my room, do not pass go, and do not collect MY $200 worth of time. Because if you try to, I will deny I was ever there. Besides, the insurance I carry will not cover it; and I won't get paid unless YOUR PRODUCTS WORK THE SAME every time i do tell it what to do.
In Science, people/you/me/we strive for the "test" that "proves" a theory/theoretical "Principle". It is the proof, or collection of datum that is the basis of such proof, which says which way all is said; and after 3 day's of "playing", my "testing" is almost complete. It is time for the final grounds to be layed onto this "machine"; a little beauty so much the cutey; looks good, blind scans good; but still not totally proven, to me and mine.
For this machine to do what I want it to; 1) It must blind scan well 2) It must motor great 3) It must pass it's final test
For the final test: 1) It will be abused (disconnected); removed (from one sat system); and channel listed through the use of a PC, and the application that provides for communications to; and programs bin/boot/the total file; and totally controls this "machine"; will now $pay for being here! 2) This program, or application must work from the beginning to the end; and communicate to the ut-most of all virtual realities; it must program 1000 channels into the microHD 3) The channels are set into the application, then applied and set into the memory of the microHD; but only after they are typed in and saved in the application; and then it will repeat this over and over again 4) If said application does not fail, then the unit (a microHD) will go into the showroom for display. 5) It must then work flawlessly, for a unit on display sells only when working perfectly!
And now a word from our sponsors!
When in the menu, do as the menu tells you to.
Thank you, and have a good day!
