C-Band help request
NightHawk
506
I know little about FTA but I'm trying to develop and test a C-band circularly polarized antenna for another reason and need a C-Band circular point source. I'm not trying to receive any particular programming, only RF. Can any of you recommend a a fairly high-powered C-band source satellite transmitting either RHCP or LHCP RF visible from the mid-Atlantic area. I think some of the FTA satellites meet this criteria correct?
Thanks for any help.
I'll look at Intelsat23 thanks.
Anole, I needed a point source at a distant high elevation and no place to mount a terresstrial antenna for this application.
Depending where you are located, Intelsat 23 may not be a very high elevation. It is 5 degrees elevation on the west coast, but could be as high as 47 degrees on the east coast.
A "portable" C-band dish
10ft Unimesh Setup/Install
