How exactly do i hook up a bullseye feed horn that would replace my exsisting co roter?
There was an old thread related to my quetion. It started out with "ordered a dual C and ku feedhorn", but you could never tell exactly how it ended. Also, i wasnt a 100% clear on everything that was mentioned.
My existing system is as follows:
* I have a dual ku/c band coroter feed horn with 2 lines (one for each) coming from the dish into the house.
* inside i split these lines using spltters and a disecq switch in order to
hook them up to 2 recievers.
* I have a 4 DTV reciever and a pansat 300a receiver. The Pansat is a
slave to the 4dtv.
Heres my real question: Since the bullseye has 4 lnbs (2 ku/ 2 c) 1 each or each polarity. And, since i only have a single line feed coming from out side (1 for ku and 1 for c) can i simply combine the 2 outputs from the ku-lnbs into the one ku coaxial line using a splitter, and combine the 2 outputs from the C lnbs into one c-band coaxial line using another splitter (i.e. 2 lines will be coming from the dish (1 c/ 1 ku with combined polarity). I'm thinking that that would be all i need to do? I would then leave the existing process inside alone (i.e. the splitting of the 2 lines using splitters and a disecq switch that are currently used to hook up the recievers).
Is anyone familiar doing this? Am i on the right page or am i way off?
Please try to keep it none engineeric.. because i am not an engineer. I am just simple hobbiest.
Thank you in advance for any and all help.
slave to the 4dtv.
