Bug Report: Unable to Remove a Satellite from the Selected Satellite List
Corrado
2,428
303
Hudson Valley Region, NY
Would there be a way to remove a previously stored satellite from the sat list if no longer needed? I have some that I originally blind scanned but no longer wish to have in the main list. I noticed if you select one by accident if makes the Micro reboot. Maybe because I deleted those channels associated with the sat? Unselecting it doesn't seem to remove it once scanned?
I didn't try using the channel editor for this reason yet. The editors seem to cause more issues than they solve for me.
We will correct this in a future firmware release.
You are correct. If a satellite can be activated using the receiver, if no channels are attached to the satellite, it should be able to be removed from the active satellite list.
Never knew you had moderator powers, SatelliteAV. :)
The firmware has been modified to allow satellite removal from the activated list. Satellites will now be able to be removed from the active list even if they have channels attached. The channels will be hidden until the satellite name is reactivated in the active satellite list.
This update will be released with the next firmware file release.
Radio Mode Bug
microHD Development: Bug Reports and Firmware Fixes
