I connected a couple of coax cables to my BSC621-2 for testing, then went to remove them to install the permanent cables. When I started to unscrew a coax cable, the BSC621-2 coax connector turned along with the F-Connector nut!
Luckily I saw this and was able to tighten the thin coax connector nut which fastens the connector to the BSC621-2, then was able to unscrew the F-connector.
So if you were to keep turning the F-connector nut and the BSC621-2 connector kept turning along with it, I would imagine that the wires connected inside the LNB would break after a few turns...
