I have my 722 hooked up to a router running DD-WRT in client mode, which bridges to my main router. Setup worked fine for a couple of years, until my main router needed replacement. After replacing the router I haven't been able to make it work since. Took me the longest time to just get into the DD-WRT router, finally was able to by resetting it then connecting wirelessly with my laptop. Resetting it put it back to the default settings, I was then able to put it back into Client mode. Went back and reset the connection in the 722 and it now gets an IP, Gateway, and both DNS' but still shows a "Not Connected" status.
I also have an XBox 360 hooked up to the same bridge, and it exhibits similar behavoir. Passes the "network" portion of the XBox Live Connection test, but fails at the next step "Internet". Gives a "cannot resolve DNS" error. However the DNS numbers listed are the same that show up in my laptop on a working connection (wirelessly straight from main router).
I'm far from a network guru, but to me this means that the bridge is working (provides IP, Gateway, and DNS to devices that are plugged in) but for some reason the main router isn't allowing requests to go out over the internet? I've rebooted everything (both routers, 722) but the problem remains. I can ping the IP given to the 722 from my laptop without problem.
Anyone got any ideas? Do I have to forward ports or something? I did notice a firewall setting in the main router so I tried disabling it. Didn't make any difference.
