Bluetooth Is Good, But Has Limitations With Hopper
Try Bluetooth, you'll like it.
1. Do you need to get a special brand to work with the Hopper?
I have used a number of Bluetooth stereo headsets and portable, battery-powered, Bluetooth stereo receivers. All worked well.
2. Is the freq. response good?
They sound great to me, but I am not a good judge due to high frequency hearing loss. HWS Bluetooth does not link to IPads or other apple devices. Don't know about Android but I doubt it.
3. Can I use them while others are listening to the speakers?
Yes, I do so. HWS has Bluetooth built in. The output is fixed and independent of the Hopper/TV volume control.
4. Can I just turn them on and use them instead of going thru menus?
Here's where HWS is limited. Every time the Bluetooth device is turned on, it must be reconnected to the HWS.
a. Turn on Bluetooth device and put in pair mode.
b. On remote press:
Yellow button
Bluetooth button
(First time only) Find Devices button
(First time only) Accept default code when device is found
Status will list your device and say "Paired - Not Connected"
Place arrow on the bar listing your device and press Select button
Place arrow over Connect and press Select button.
<HWS does not find your device every time so you may have repeat the last step>
Listen.
5. Do you have to mess with volume settings?
Not for the TV - can even be muted. I find that an amplifier (portable or built in) on the receiving end is essential. Most people will want at least a volume control (turns down the volume but not up.) YMMV.
Having to reconnect every time is a pain. Also, HWS will only allow two devices at a time to be paired - connected or not.
Still, I find Bluetooth to be the best option. Hopefully, Dish will improve things on their end?
I am pleased with Meee and FiiO brands. No-name devices work fine as well. I like the MEElectronics AF9-BK since I can use any headphones with it and tuck it in my pocket. Battery life is about four hours so I have two. They recharge in about an hour.
