audio2000 said:
so basicly your telling me if i put the reed thing on there even tho it has the 37:1 ratio motor it will still be fine even tho theres the warning that says 70:1 ? already drilled some holes on the birdview schlar plate and got a new chapperal feedhorn mounted just fine and it dose work already tryed it with a new reciver however i found a Ku-Band analog channel that was kinda stacity but C was clear just needed to do the reed thing with it then get ahold of a Digital Reciver for it at a later date :-D isnt it fun reviving something that was installed when you was 4yrs old lol..
On the reciever I use with my Birdview the count jumps in 4's but my 10'
dish with another receiver the count moves in 2's so if I hit east and I am on
say 5000 it will go to 5004 on the birdview but other then that it is working
very well and will hit all my sats with no problem, I had no problems with
getting sparklie free analog on either C or Ku bands and in fact it works better
then my 10' dish in high winds because it is so solidly built that it does not
move around. My other dish is an Orbitron C10 and it has problems in high winds, also on the Ku analog feed that had problems sometimes it is because
the channels that are in the receiver for KU are off and you can fine tune
it and get a good picture, my best analog receiver is a Chapparal Monterey
95 and I can set the KU frequencies to anything I want on another receiver I
use a G.I. 450i I have some sats where the channel frequencies are wrong and I just fine tune the frequency.
