Yesterday, I tried blind scanning GB (97W/ Galaxy 11/Galaxy 17) for C band channels.
The Blind Scan started okay, but about 57 seconds into the scan the blind scan screen suddenly reverts back to the DISH SETTING screen. I could not even exit out of the Dish Setting screen.
The SV360 had locked up, froze. Soft reboot had to be done. So, I tried the blind scan three more times having the same result each time.
The SV360 is slaved to a Motorola 922. The 922 was sitting on a channel (GB satellite) that has 100% signal and 95% quality.
The SV 360 Elite has the original factory firmware loaded. I have never updated or changed the firmware since buying the STB about 2-1/2 - 3 years ago brand new.
I last used the blind scan function about 3 months ago, and it worked perfectly.
I also tried blind scanning two other satellites with the same results: locked up/froze. Soft reboot done.
I began checking out other functions: adding a tp, renaming a channel, moving a channel, scan tp, scan sat, deleting a channel.
Results:
Main Software 01.07
I really don't want to do a factory reset cause I'm not sure exactly what will happen other than the slate is wiped clean, and I have to start all over again. Plus, the blind scan still may not work.
Is there some way I can save my settings and/or channels on a stick? Then maybe do a factory reset? Then reload my info?
Or, is there an update to the firmware that might correct the glitches without losing my information?
Or, if I were to reload the original firmware, would the info be saved or would doing this be just like a factory reset?
Results:
- Adding a tp: could enter the information but the new tp was not put into the TP list.
- Renaming a channel: worked just fine.
- Moving a channel: worked just fine.
- Scan TP: Did not work.
- Scan Sat: Did not work.
- Deleting a channel: worked just fine.
Main Software 01.07
