I figured today that maybe a loose bolt might be causing alittle slippage when moving dish so i tightened polar mount nuts,mast nuts,etc and when i went inside to check some stations poof!!! lost most of my ku and c .Well! after cooling down abit knowing that something was off i went out again to see what happened!I had to redo two adustments!one was the dish elevation was off and the mast mounting nuts also needed adjusting.I was lucky and it took me only half an hour to get things just right again.So!! when ever you decide to tighten or loosen some bolt!keep an eye on the tvs Q.
