So I was replacing the mast on my OTA HD antenna, which consists of 2 CM 4228's mounted one over the other and connected together, and despite the greatest of care, I dropped the mast and bent the heck out of the 4228's. One got it worse than the other, but both were bent up to some degree.
I unbent them by hand as best I could, but even though they look OK, they are still not totally right, in that most of the components are no longer completely 100% plumb and level (i.e., the screens have some small amount of wave and curve to them, the bowties are slightly out of plumb with each other and the screen, crossbars have a very small bend in them in the middle). Because of the way the antenna is constructed I found it pretty much impossible to get the assembled antenna hand-bent back to its 100% original condition.
The unit basically works, although I can't really tell whether I'm getting the same level of signal and performance as before the "accident." I haven't tried to disassemble the antenna (i.e., pull the screen off the bowtie assembly), get out the tools, and try to bend everything back completely true and plumb because I'm not sure whether it would be: 1) possible; 2) worth the effort. Anyone have any experience with this or have an opinion on the degree of "foregiveness" here - As with horeshores and hand grenades, does "close" count with antennas?
