My first 9242 had rebooting issue and was replaced by Bell with this refurbished one 4 years ago. It had worked fine until 2 weeks ago. It won't boot up. The green light comes on and the fan spins up and then the light goes off. In 2 minutes it reboots again. I tried unplugging power and data cables to the hard drive and the receiver still got into the same rebooting cycle with black screen.
I checked the voltage levels at the output of the power supply. Some are out of spec: 25.7V vs 24V spec, 18.4V vs 17V spec, 8.3V vs 7.5V spec. The 12V and 5.1V outputs are on spec. The heatsink for the power rectifier diode MUR1520 gets very hot in like 5 minutes. The power supply does not tick, though.
I also checked all capacitors and only noticed two capacitors bulging underneath the power supply board. They are C394 and C363, both 1200uF. Neither of them are known locations of capacitor failures on 9242 as listed on the other site.
I own this 9242. What should I do? Replace the two bulging caps and/or MUR1520 rectifier diode or look for something else? I appreciate any advise you may have.
