So, I managed to find a 5100 (with 5900 hard-drive upgrade) on ebay, and the other day I had that activated in place of my good old 2700. The 2700 had been working fine, with good signal strength and no problems in the last month or so.
Everything was good with the 5100 for about the first 20 mins (ie, while on the phone with Bell), but then the signal started dropping out. I'd get the "searching for signal" or "lost signal" error messages for 1-2 seconds every 10 seconds or so. I went to the signal strength page. Many tps had stronger signal strength than previously (I now have 5 or 6 tps with 100% strength, including one on 82W!) - however periodically the signal meter would turn red and say "wrong sat". Usually, the actual signal strength would not drop - it would just unlock. Occasionally, the signal strength would drop down to zero for 1-2 seconds as well, but usually it was just the unlocking problem.
So, I just pulled the satellite cable back out of the 5100, and hooked up the 2700 again. There is no problem. I sat with the signal strength display on the screen for 10 mins - 5 mins each of 82W tp4 and 91W tp11. While the signal strengths were ~ 4-6% lower than measured on the 5100, both tps remained locked the entire time, with strength fluctuations of no more than 1% during the 5 min period. Since then, I've had TSN on the 2700 for the last 15 mins, with no signal loss.
Does anyone have any thoughts? I have a 20" dish with two legacy dual LNBs and a SW21. (The 5100 had been setup to run with a DP twin, but I did a check-switch and reset it to my apparatus within the first few minutes of hooking it up to the dish.) The cable run to the dish is probably only 20-25 feet. Is there something about the 5100 or DP-series receivers that might be causing this.... or is the 5100 unit just flaky? (Also, I'd asked for the 2700 to be deactivated - should I be getting any subscrption channels on it??!!)
