B1 SAT STACK C-Band LNBF on 1.2M Dish
Thanks Ice! Since the BSC621-2 and the replacement GeoSat C/KU Band LNBF are weak on the KU side, I would like to have separate C and KU LNB motorized on a 1.2M dish. Does it matter which LNB is center and which is offset? Which do you setup first?
in the pic above both are C-Band. Its on a fixed system where it was setup as 91/99. I have since moved the dish to 99 only
Need Help
Issue with Create on AMC 21
