To make it a bit easier to setup the AzBox ME for North American use, we at AzBox Canada have created a customised version of the AzTrino operating system. Based on the current 1.6 version, it includes the following enhancements:
- Numerous menu items and options were renamed in order to fix grammatical errors in the English user interface.
- Current North American satellite list from 1W to 177W separated by band where applicable.
It is available for download on our website at AzBox Canada :: Official Canadian distributor for AzBox products under Support.
We also released a HOWTO document on how to setup a USALS motorized satellite system when using this firmware which can also be found in the Support section for download.
Notes:
Due to issues with 1080i and 1080p 60Hz resolutions, we recommend that 720p @ 60Hz resolution be used at the moment if your TV does not support the PAL format (i.e. 50Hz).
Please note that we are aware of the following issues which will be resolved in future versions: (Priority items are in bold)
Regards,
PwrSurge
AzBox Canada
Notes:
- Channels with no name won't scan in.
- No picture with 1080p @ 60Hz or 480p @ 60 Hz resolutions.
- Missing 480i @ 60Hz resolution.
- Excessive overscan regardless of resolution.
- Audio cuts out and sometimes get a strange hum when using 1080i @ 60Hz resolution.
- Transponders found during blindscan don't scan properly as it appears IF is not being calculated properly. Added transponders don't have the correct frequency.
- SNR level meter reads lower that what it should be
- Image from last channel stays on screen until new channel comes in
- Graphs not working when selecting channel details
- Mono left or Mono right audio mode not working
- Blindscan never starts unless you select an active transponder first in manual scan.
Regards,
PwrSurge
AzBox Canada
