I have a Premium with a 1TB Hitachi HDD installed. If I leave the top cover off the AZBox, everything is good.
When I put the top metal cover on the AZBox I start seeing a herringbone pattern in the component video output in about 5 minutes. These are parallel lines running through the video from the left side of the screen to the right. The left side of each line is slightly higher than the right side.
If the top cover is removed the lines fade away after about 5 minutes.
I have tried this with and without the hard drive, I've tried insullating the metal top cover so it can't contact the rest of the unit, I've made sure I'm not crimping any lines and I've replaced the SATA data/power cables. Nothing changes anything. I've also moved the unit around and also plugged the power supply into a different outlet.
Topday the interference with a high speed MPEG2 stream was to a point it looked like vertical streaks (very different). Removed the cover and the problem went away.
Is it possible that the cover is pressing into the main board somehow?
I'm really starting to wonder if this normal and people just aren't using component anymore? Also does HDMI work if 1080i is selected as the output? Seems to go blank for me.
Thanks for any help!
Andy
Andy
