Hi everyone;
I’m in all quite happy owner of Azbox Premium+. It is an amazing receiver but unfortunately it developed the following problem:
“also sometimes when I say "sleep" and try and power back on, there is a HDMI handshake issue....sometimes wont send signal to HDTV
this is version 4075...going to try 4056” (end of Quote)
Did anybody else encounter similar problem? If so, any advice will be greatly appreciated.
Thanks.
- HDMI has a hard time “waking up” after sleep (remote control to turn the box off and on). The only way to reactivate HDMI output is to reboot. Composite and component outputs work normally and stay in proper resolution and in NTSC mode when it happens.. The same HDMI input and HDMI cable on my Samsung TV work 100% reliable with other HD devices such as PS3. I also tried Dell monitor with HDMI input and still no wakeup. There is no difference if I use different resolutions, but my native res. is 1080p.
- It started to behave like that after editing / adding some satellites by the remote control (not sure if it is a coincidence or not).
- I was able to restore the HDMI working normally, after re-loading firmware with the default satellite list and formating application area.
- Editing satellite list made this problem to come back? (Prior to satellite editing, hdmi was working every time, after editing it is intermittent.
- I do need HDMI for my normal hookup, I don’t want to reboot receiver every time I turn it on with the remote. I’m using 0.9.4991 firmware. I tried 0.9.4931 and the same thing happens.
Thanks.
