AZBOX Premium HD - can't edit "TV Cannel\IP Channel\HTTP\TV Type (kartina.tv)\Address" field
vpaniyan
55
US
After AZBOX Premium HD FW upgrade from 4717 to 5306, I can't edit the "\Setup\TV Cannel\IP Channel\Protocol=HTTP\TV Type=kartina.tv\Address" field.
Cursor jumps to the next field instead of stop on the "Address" field and highlight it for edit.
Any ideas appreciated.
vpaniyan,
I have had similar observations with other IP channels, even prior to image 5306 (as far back as 5020 and possibly before that). I even had troubles deleting the channel so that I could start fresh, but try deleting it and see if you are allowed to do that. Otherwise, try to add a new IP channel with the desired changes. Beyond this, you will have to try the editing operations using the external editor program (AZEdit + ACC or MazEdit + ACC). Refer to the AZBox A-Z Guide in the stickies. That is the best I can do for you at this time. I don't have a precise guide for the procedure at this time.
RADAR
Radar,
Let me explain what I'm trying to accomplish.
I use build-in IPTV/kartina.tv (build-in IP address URL http://iptv.kartina.tv , you can't modified it) - it works great, I have more than 100 channels, BUT it doesn't download EPG.
Several months ago, I found a solution for this problem - with FM 4717 you can modify the "IP address" field.
I downgraded FW to 4717, installed WEB Interface, installed a program that can get the channel list and EPG, and modified the "IP address" field to point to this program http://localhost/m3u/playlist.php.
This program downloads channels and EPG with no problem.
Recently, I decided to upgrade FW to the latest version 5306.
With this version the "address" field is not editable anymore.
This is where I'm stuck - can watch TV with no EPG.
I think this is a file permission issue, but I don't know what file has the address field.
At this point, I see only one way to fix the problem - downgrade FW to 4717 as I done it in past.
Delete channels doesn't help.
sorry for my stupid(?) question....my azbox premium was installed the latest firmware version 0.9.5308 and i m getting only 4 ip tv channels with http://iptv.kartina.tv .....and how i can get more than 100 iptv channels? need to install any other s/w? and have any other IPTV urls to add more IPTV channels?
sorry for lot of questions...but i m very new for this box!
regards-george
Radar,
I use build-in IPTV/kartina.tv (build-in IP address URL Картина.ТВ , you can't modified it) - it works great, I have more than 100 channels, BUT it doesn't download EPG.
Four channels are free demo.
You need to buy kartina.tv service and will get about 105 Russian channels.
If you can edit the field mentioned in this thread and install WEB Interface then you will get about 130 Russian channels - extra radio and XXX channels.
AZBox Elite and Ethernet Problem
