Don't be caught with your knickers down!
There is a very simple method to save (backup) your satellites, transponders, channels, LNBF type and L.O. frequencies, motor and switch settings. If you have done a lot of work to create your own personal list of these items, you don't want to have to repeat all that work (entering new sats or TPs or scanning for channels) if you don't have to. Guess what, you don't.
Format a USB flash memory stick with FAT32 system.
Insert this flash drive into your AZBox USB port.
Select SETTINGS > SYSTEM INFORMATION > BACKUP/RESTORE
Press the RED button on your remote to BACKUP the file/s to your USB drive.
You will be prompted to save the file to: /Data/usb1/sda1
Press OK
When the files have been transferred, you will be presented the message:
"Backup completed successfully"
Press the USB button on your remote and the message "Eject USB" will be shown on the TV screen indicating that you may safely remove the USB drive from the receiver.
The file saved will be: CHANNEL.bak
There are two other file folders that will be created (pvrfile and recordfile), but they will usually be empty and you won't require them for the restoration process.
This is a very simple procedure and extremely worth the few seconds it requires to complete.
If your AZBox should crash or become corrupted somehow, you have this list to restore your previously known working setup of satellites, transponders and channels as well as motor, switch and LNB L.O. settings.
To restore your data, simply insert the USB drive with the CHANNEL.bak file on it in your AZBox USB port, navigate to SETTINGS > SYSTEM INFORMATION > BACKUP/RESTORE and press the BLUE button on the remote.
A very nice perk! Enjoy.
RADAR
Press OK
RADAR
