Back in April I put into service 2 PLL LNBFs. One on the 33” dish pointing at 30W and the other on the 25” pointed at 97W.
Didn’t notice much if any change on the 33” dish, the Q only changed a bit higher.
The 25” dish did benefit the most from the PLL. It picked up 2 additional TPs and also some marginal channel were now rock steady.
Since then I re-installed my Stab motor with the PLL LNB from the 25” dish onto a Fortec 31” dish.
Here’s the interesting part. I blind scanned 97W and the S9 got every TP available and about 4 extra TPs not listed in the Lyngsat or Sathint sites. After some research I discovered they additional TPs were from 99W.
Likewise when I blind scanned 99W there appeared a number of TPs from 97W.
Also spill over of TPs when blind scanning other sats.
So I removed the PLL and put the Invacom QPH-031 on and rescanned 97w. Adjacent sat TPs did not appear. Also rescanned 97w with a GT-LST40c LNBF and it also did not scan in adjacent sat TPs.
Has anyone else observed a similar effect with or without a PLL LNBF?
