Fix for glitching and menu problems.....
Well I've had problems with micro-glitching and menu info since I received the new software last week, just like some others I've seen in here. I soft and hard rebooted my receiver several times...no luck. So I called Customer service and got a fix. I hope this can help a few of you.
So the fix is. Tune your receiver to a Voom channel. This fix possibly will not work if you start it while tuned to a OTA local channel.
Soft reboot your receiver.
Go into the installation menu and do a scan for local channels.
Note which ones are below 86 on reception.
Now go back in under options and settings, and then under channel list and hide the ones that are below 86 by pressing OK.
Wait five minutes and do a soft reboot.
You should now be okay.
It cured my problems immediately. I have menu info and no pixelation or glitching. The CSR at Voom said any locals below 86 would keep the receiver from downloading info and cause the glitching for some reason. Well whatever the reason it worked for me.
