Audio problem from Traxis 2500
sksatellite
616
First complain from customer on this receiver which sold to him month ago. The audio is getting weak, last check two weeks ago was that the audio has very strong base back ground and not as clear as first in use.
THis could be a small problem which may just open and fix, but since this is a kind of new model receiver, do you think send it back for repair so the distributor can eleminated the problem for future ?
If you open it up the warranty is null and void, I would send it back for 1st class service, I would also try all the audio channels, but I am sure you done that, last resort a factory default?
You are welcome to send the receiver back under warranty and it will be repaired and returned at no charge. Please see http://www.dmsiusa.com/ra_form.htm or call our service department at 770-874-1079. I require repairs to be turned around within three business days so your customer won't wait too long. Let me know if you have any questions.
Tim Heinrichs
DMS International
Ac3 On Satwork 3688
Primestar receiver, how do I change the setup to find stuff?
