I'll try to explain issue as best as I can...A lot of the APIDS with the Micro come up with numbers starting with "8" or something 4 or 5 digits long.Not always the 8191 PID either. Some of them were 5 digit which I hadn't seen before.
You change station ID to zero so you can edit the channel name and it doesn't overwrite it next time you blind scan..at least my openbox worked that way..The Micro wants you to change the PID. If you change it to anything else the there's no audio on the TV after you save your changes. PBS 125w is a good example. How's is everyone keeping the Micro from overwriting the changes you made to the channel name? I must be missing something simple.
Next issue: Also I get audio on the CW's on 91W except the Eastern one..Thanks Blind
