Audio output low.....
cruzmisl
114
I noticed when watching RAVE yesterday that I really have to turn the volume up on my system to get some good output. On RAVE for example I can turn it up to +10db (max) but the system isn't as loud as it could be. I have my system calibrated and when playing DVD's at reference levels (85db) I usually have it set at -5db. If I Were to play a CD or DVD at +10db my ears would bleed :)
Any suggestions or is this just the way it is?
Thanks,
Joe
BTW, this happens when using coax or toslink outputs.
Thanks,
Joe
Joe, you can go into the setup menu and select uncompressed audio or compressed. I run mine uncompressed on the Voom STB and then use high bit sampling on my Pioneer Elite receiver. Rave sounds fantastic with the uncompressed audio stream but you will have to experiment with your setup. The really compressed mode evens out the audio level for most of the Voom channels to where they are about equal. The lower volume channels will sound louder on that setting. You would think the opposite would be true.
Spots and lines in picture
No Signal on Digital Coax Output
