Audio issues
nightowl66
56
11
N.W. Ohio
I have a old Panasonic plasma tv model TH-50PZ77U with a Yamaha sound bar model ATS-1010 out in my shop. The sound bar is connected to the TV with a optical cable. I started noticing sound cutting out on Sun night football. Every time they would show a replay with graphics, the sound would cut out for the first couple seconds while the Dolby light flickered on the sound bar. Same at the beginning of commercials with graphics. Then it is OK the rest of the time until another replay. I tried different settings and optical cable with no luck. I brought another TV out and hooked it up and the sound is fine. So the problem is the TV. Audio over TV speakers work OK without sound cutting out.
Any ideas?
If you can't solve the TV's problems by doing a factory reset, I can't imagine how you're going to otherwise repair the TV's Dolby handling. Finding repair parts for a 13 year old model is unlikely and finding someone who repairs TV may be just as hard.
Since there isn't a menu option to select full-time PCM rather than Dolby Digital, you're stuck with respect to your current sound bar. The TV's automatic switching feature obviously isn't working consistently. From page 53 of the manual:
TV Manual said:
If digital sound connection has a problem, select analog sound connection.
There's your sign.
Sound bars of every kind are pretty expensive so maybe you've got an old boom box laying around? It is imperative to use the RCA outputs as those don't involve Dolby 5.1 (just as the TV's speakers don't).
Who knows about Roon Labs?
Lower end 55 inch TV
