After a month and a half scuffle with directv and my local directv installer I am finally coming to the conclusion that if I want directv HD I am going to have to do al the work myself. I am looking on eBay to by a dish but am having trouble finding a slimline without the seller over charging for shipping, however I was able to find a very reasonably priced AT9. I put a bid on it and am aware that this style of dish is harder to maneuver and align due to its bigger size and heavier weight. I am looking for any tips on installing this older model dish. I am trying to avoid any more extra costs besides the necessary installation materials, so I'm hoping to do without purchasing an expensive signal meter. Any advice would be great.
First of all, it's not that much different to set up and just because the newer dish is called a "Slimline" doesn't mean it's that much smaller.
Physically it's slightly smaller overall, it's a different shape, the Slimline is longer and shorter, the AT-9 is morelike the size of a pizza box.
The AT-9 is said to be 32 lbs and the S/L is 25 lbs, hardly enough to say to not get one over the other, they are both heavy.
A lot also depends on where you plan to put it, on the roof, ground or pole mount.
I have done a Pole mount and a roof mount with the AT-9 's, I haven't had the pleasure of setting up a S/L yet, some installers say they are easier.
I do not own a meter and have had no trouble getting good solid signals in the 90's.
As long as you have a good clear line of sight. the first place I was going to put one was not a real good place and I did have trouble getting the 119 in, once I relocated it, everything came in right away, no problem.
to the site !
Jimbo
