AT9 and receiver question
sheridan
165
I keep reading on the AT9 specs that I must use the H20 receiver. Why?
Also, I was considering the HD300. Without getting into a Ford vs Chevy argument, can someone tell why I should or shouldn't consider this receiver?
And never mind what I can get for free if I let D* do the install. That's not gonna happen.
Thanks.
Just guessing here, but maybe because the H20 supports all 5 satellites on the AT9 and, most importantly, it supports the mpeg4 encoding that the HD streams will use?
Ah, and I take it the HD300 does not?
Is the H20 the only choice or is it the best choice?
From what I can see, the HD300 does not support mpeg-4 (there could be forthcoming modules for it, I don't know.).
And it seens, yes, the H20 is the 'only choice' at this time for decoding mpeg-4 D* streams.
That kinda narrows it down. Thanks for clearing that up.
When you mentioned modules, are you talking about a hardware or software upgrade?
Hardware, I only saw mention of it along with other receiver models, and even then, it only mentioned the 'possibility' of one, so I am not sure if it applies to the HD300 or not.
If you're talking about the Sony HD300, then the answer is NO. Sony no longer makes D* receivers... the SAT-HD300 was a rebadged LG.
Looking for advice, help as related to reactivation, etc.
Question on HDCP
