I called to switch to HD from SD. They were able to do it with just my tel #.
Mitch
I just had 2 SD boxes replaced with HD boxes. Don't know how quick the database they use is updated.
Mitch
But I would trade Chicago for Kansas City if that choice were avaliable.
Adam:
Welcome
Please pass this along to your marketing folks.
It might be a whole lot easier to sell an 18.99/month HD package on the east coast if you offer the NY channels in HD. There are a huge amont of people on the east coast that are would be a lot more interested in NY than Chicago or LA. and since the NY markert airs at exactly the same time as the Chicago market there would be no time zone issues. Just more subs!
Mike the bossman probably found out about it.OK so where did Adam go?
Adam, or anyone else who knows:
I have been trying to help a friend who lost his CBS channel with the digital transition. After installing a new antenna system, which would not pickup the channel, he finally ordered DISH, because their rep said he could get locals. That turned out to be incorrect. So he decided to go ahead and order dish and AAD for the CBS feed. Dish had to set him up with 77, 72, and 61.5 satellites instead of 119, 110, 129 because of obstructions. He spoke with AAD; they said this was not a problem, and they sold him the CBS package. It never worked, and he called back several times. Finally someone at AAD told him that it is not possible for him to get the CBS feed on his satellites. Does anyone know the correct information on this?
Are you saying that he could get the Chicago HD CBS feed on 61.5? That is one of the satellites he gets, but the latest AAD person told him he could not get it. If he was wrong, can you give me a link to something official we could mention to the AAD rep?dish set him up on eastern arc with a 1000.4 dish. As you mentioned above that is sats 61.5/72 and 77. AAD sd channels and hd channels are on 110 and 119. This means that your friend needs a dish 500 pointed to 110/119 and a separate dish pointed to 61.5 for HD programming.
I don't know if dish will do this for him however.. probably not.
Gerry
Thanks,
Charles
Thanks. When Dish looked at his setup they said that the standard setup would not work, because they needed a clear path to several satellites, and the trees made that impossible. Technically, if they could get just either 119 or 110, then would that be sufficient for him to get either the SD or HD AAD signal? And would he need any other special equipment to merge the signals from that satellite with the ones he already gets?I said that ALL AAD programming is on either 110 or 119. SD is on one of them and their HD versions are on the other one.. I was referring to Dishnetwork HD that is on 61.5...
Again, there is not any AAD programming on the sats that your friend is pointed to. Sorry for any confusion.
Gerry
To be more specific: AAD SD is on 119 sat and HD is on 110 sat....
