I give you a solution.
required items
2-2way splitters.
3 - short (3-4in) rg-6 jumpers.
ON the back of your dual tuner remove the uhf antenna. place 1 of the jumpers here and run it to a splitter turned around (you are combining). run another of the jumpers from the tv2 output to the other in/output of the splitter.
attach the cable that goes to the second room into the single side of the splitter.
Now go to the other room. disconnect the cable from the back of your tv.
attach it to the IN port on the other splitter. attach the last juper to one of the outputs and to the tv. attach the UHF ant. to the other output.
you are now combining the remote signal down the coax directly to the receiver.
problem solved.
required items
2-2way splitters.
problem solved.
