Are HR22-100 dimensions exactly the same as HR21-??
mwardncsu
7
I need to order a Middle Atlantic custom rackshelf and they do not list the HR22 in their database yet. They list the HR21-100, -200 & -700. Given the need for very exact dimensions, does anyone know which one of the HR21 models the HR22 is based off in terms of the physical external casing / manufacturer?
thanks.....
HR22
Product Height
2-4/5"
Product Width
15-1/5"
Product Weight
8 lbs.
Product Depth
11-4/5"
HR21
Product Height
2-3/4"
Product Width
15-1/8"
Product Weight
9,4 lbs.
Product Depth
12-1/4"
When you look at buying an HR22, figure the submodel (-100 -200 or -700) would tell you which hr21 would match.
Each manufacturer may have slight variations in their casing.
Thanks - I believe my HR22 is a "-100" model but will confirm - unfortunately I can't trust the product spec dimensions since a dedicated faceplate will be cut out which requires both tight tolerances but also appropriate radiuses, etc. May have to just send it off to Middle Atlantic and let them measure & return.....
HD Dish Size Question
Am-21 Tuner and H-21 HD Receiver
