Any success out there?
Received the unit this evening.
Installed the latest firmware 1.7.13
Downloaded the Dish Network plug. The instructions indicated that the update could take a minute. I tried it a couple times and did not think it worked. Where I was unsure was when I unplugged the 705 from the computer and it said there were 2 files to install. I clicked install, it requested I plug the AC power in and pressed ok - I blinked and it was done.
So I then hooked up the 705 to the 722. It was recognized as a 705. I did have to disconnect the external hard drive.
First bad at this step - won't take HD programs and downsize them as SD to go onto the 705
Second bad is that I transferred a SD program from the external HD to the 705. 800k file transferred in < 1 second. Does not appear on the 705.
I'll have to get ahold of Archos tech support unless someone has already gone through this and figured it out.
Thanks.
Thanks.
